Project data & BIM
SOLVED!
Window Type legend Schedule
Gisele
Attached are the window types that I need to include in the window legend.
What should I have in the scheme settings criteria? I tried three different ways, in vain:
1)  library part name is Window
2) Element type is Window
3) ArchiCAD Classification 20 is Window
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
1 ACCEPTED SOLUTION
Solution
scottjm
Mentor
Check you have the correct renovation filter on when viewing you schedule.  I note you have the window set to 'New', so make sure you're renovation filter is not defaulting to only showing existing elements.
The renovation filter setting is independent of the schedule criteria and has caught me out on many occasions.
2 REPLIES 2
Solution
scottjm
Mentor
Thank you!
