Learn more
ZONES_control
Simple and hope very simple answer as to why my control of zones is not working ?
see screenshots.
the correct classification is used : see the GRAPHIC OVERIDE SETTINGS - both the overide settings and the respective settings for the classification - zone. Also atatched.
No idea why the zones are not appearing in 3D as volumes in blue as they should be.
file is in FR - but you get the idea
ThX
15 Replies 15
perhaps you cud screen shot each pulll down ?
thought i was with you : then i saw your text in brackets?
if you could send a screen shot of each pull down - .
element type IS zone -->
floor level = 0.
tHIS IS WHERE I AM AT. THIS IS FOR RULE 1 FOR E.G.
furtonb :
you have lost me on the rules i think - cant work out how to add these 3 rules as you mention ??
i am trying but i dont seem to have got it.
furtonb
Download the attached zip (it has 1 .xml file in it) and import it to your Graphic overrides.
Change the rule setup: home stories, surfaces, element type, and delete the unnecessary rules if you want.
Also, I think it would be helpful to read the related HelpCenter article here: https://helpcenter.graphisoft.com/user-guide/76882/
odv.hu | actively using: AC26-28 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
THANKS I WILL IMPORT IN TO A NEW FRESH FILE AND TRY AND UNDERSTAND WHAT YOU HAVE DONE.
You definitely need to read the documentation on graphic overrides. It will make your life much easier
