Christina-SQ1
Zone Stamp - Changing scale sensitivity to 1:20
Hi, I would like to change the scale of my zone stamps to 1:20 for more detailed drawings. As I have read in other relevant posts, the zone tool is a GDL object residing in the ArchiCAD library and the scale sensitivity of the zone stamp is coded at 1:50. The only way to change the scale from 1:50 to 1:20 is by self-coding the zone. Can someone guide me on how to do that?
1 Reply 1
What version of Archicad are you using?
From 25, you can use zone labels instead of stamps.
You can add as many labels as you want, in different layers and for different scales.
You can even add labels in section.
