Zone Tool
I used to know how the Zone tool worked but it seems more complicated than it used to be so I need a little help..
The only thing I need is how to access the <floor type>.
Using AC 22 and Zone Stamp 01 22
I just want to put in tile or wood.
I can't figure it out... and I've gone thru some tutorials which were older and seemed to have easy access to make it work...
any help would be fantastic
Dave Seabury
Jeanie
You will need to look into Options>Classification Manager and set up your finishes there.
then pull them in to the zone stamp and schedule.
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
Lingwisyer
Guru
Settings => Content Order
Make sure Finishes is listed there for your relevant scale/s.
Settings => Finishes, Heights => Floor Finish
Ling.
