Project data & BIM
archicad/HBIM
LM2F
Hello group! I would like to share a doubt I can develop some kind of map for identifying and cataloging pathologies with tools that are easy to model, as shown in the example below
This image is taken from an HBIM example from the edificius software by acca-software if you could create schedules showing examples of pathologies (shapes or colors as shown in the image) it would be perfect!
I appreciate the help of the community for the development of archicad/HBIM
I would probably try to achieve these patches using images with alpha channels, placed using the Figure Tool in Elevation Viewpoints.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
While custom textures or fills aligned with walls would allow for some of the historic pathology that you illustrate, it would not allow scheduling/etc.  Looking at edificius, it seems tailor made for the situation that you are describing - so I would wonder why you wouldn't just use edificius and use the resulting model as a reference model in Archicad - assumning that ediificius can export in a useful format?  I don't think that there is enough demand to add any of these features to Archicad itself (yours is the first time I've seen a desire to catalog cracks/etc in existing buildings).
https://www.accasoftware.com/en/hbim-historic-buildings
One of the forum moderators
AC 26 USA and earlier   •   macOS Ventura 13.5.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
