Project data & BIM
complex profile update
Hello.
I have an issue regarding complex profiles. I draw one and use it. However, when I edit and therefore change it, it does not update. The elements already in use do not have the new attributes and I need to draw them all over again.
Does anybody have any idea how this can be solved?
Thank you,
I.G.
David Maudlin
igreere:
Did you click the "Store Profile" button in the Profile Manager dialog box after editing the profile?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hello.
Thank you very much for the answer. I did add a signature to my profile, I hope I did it well.
As for the complex profile update, yes, I did hit 'Store profile' and did not work. Is there any difference between 'Override' and 'Store Profile'?
Thank you again.
I.G.
David Maudlin
Looks good. There are some differences in the Profile Manager between AC16 and AC17.
Yes, see the Help files User Interface Reference > Dialog Boxes > Profile Manager Dialog Box. To save changes use "Store Profile".
A few things to check:
1. That the Profile in the model has the same name as the one you are editing. If it is "custom", then it is hard to know what is what.
2. Make the Horizontal and Vertical Stretch Lines visible in the Profile Editor. A Profile cannot be smaller than these limits.
3. Rebuild the Section/Elevation/3D Window.
4. Select the Profile in the model, change it to a different Profile, then back to the one you are editing to make sure it has the correct assignment.
If none of this works, then post a detailed description of your procedure with some screen shots of the problem. This may help someone see the issue.
David
