‎2007-12-31
03:12 PM
‎2023-05-30
12:54 PM
Rubia Torres
‎2007-12-31 05:22 PM
‎2008-01-01 04:37 PM
Thomas wrote:Another way is to hide and/or lock all your layers. When you merge the the file it will ask whether you want to show & unlock, create new, or just put everything on the ArchiCAD layer.
If it's a DWG, just drag it in or use Place External Drawing.
An item from another Archicad project will carry its layers with it unless you
- make it an object (best)
or
- place a view (from the other project, showing the item) on a Layout and show that as Trace Reference - then you can trace it.
‎2008-01-06 07:08 PM
