Project data & BIM
hotlink module
i have a typical floor to be the module for a high rise building and i have to place it every floor. then i have to repeat clicking the mouse . and there is no shortcut key for placing hotlink module.
what is the easiest way to do so???
Link
You can always assign a keyboard shortcut to the 'Place Hotlinked Module...' command. It will remember the last placed module by default.
Link.
thanks
i notice that i can assign any command easily and manully
