2012-03-20
09:08 PM
2023-05-30
01:11 PM
Rubia Torres
2012-03-26 11:49 PM
2012-04-28 12:04 AM
2012-04-28 07:37 PM
Geoff wrote:The mapping is determined by the translator used. I usually use the "keep pen index numbers" or a copy for interoperability. Otherwise I think it will try to match the colors or something. You can also specify the mapping pen by pen in the translator settings if you need to (FWIW I never have).
I have a question for you guys. If I look at the Drawing Pens & Colors of a drawing who's source is a DWG it shows the pens used. But how are they mapped to those particular ArchiCAD pens? For example, I insert DWG detail with the drawing tool and it shows that pens 1, 2, 3, 4, 7 and 51 are used. These are the same pens the resulting elements use if the drawing is exploded. But why those?
2012-04-30 08:09 AM
