Project data & BIM
layer in PDF
hi
When I export from autocad to pdf the pdf file contain layers and ability of turn it on or off how cad save from Archicad to PDF with layers directly
thank all
From ArchiCAD save your file as a .dwg first, then open that .dwg with the Acrobat.
Acrobat does not seem to support .dwg format. Is there a plug-in or add-on needed?
You need Acrobat Pro (not Standard) and I think it has to be version 9 or later. If you don't have it you can download a 30 day trial. I'm pretty sure it's fully functional. That will get it done for now and you can always buy a license before the trial period ends if you want.
