Project data & BIM
layer in PDF
hi
When I export from autocad to pdf the pdf file contain layers and ability of turn it on or off how cad save from Archicad to PDF with layers directly
thank all
3 REPLIES 3
Steve Jepson
From ArchiCAD save your file as a .dwg first, then open that .dwg with the Acrobat.
Acrobat does not seem to support .dwg format. Is there a plug-in or add-on needed?
You need Acrobat Pro (not Standard) and I think it has to be version 9 or later. If you don't have it you can download a 30 day trial. I'm pretty sure it's fully functional. That will get it done for now and you can always buy a license before the trial period ends if you want.
