We value your input!
Project data & BIM
migrating from AC9 to AC11 (i Cant Plot)
i just upgraded from AC9 to AC11 but for some reason when i go to plot a drawing it does not give me the option of selecting my office plotter as an option.
1 REPLY 1
Rick Thompson
see
http://archicad-talk.graphisoft.com/viewtopic.php?t=17043&postdays=0&postorder=asc&&start=130
for a discussion
from GS...
From the Connection pop-up, you can specify whether a local modem or printer port is used, or choose AppleTalk or TCP/IP protocols for network plotters. When TCP/IP protocol is selected, click the Setup button to enter the IP address (or fully qualified domain name) and port number of the desired network plotter.
However, I didn't do this. I use Plotflow. Plot to a spool folder and set Plotflow up as before. That wasn't changed.. yet. I would recommend Plotflow anyway. I haven't plotted directly from AC in years. Plotflow is great. You can spool to it, then shut down AC, or move on to another PLN, and the plotting continues.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
