Project data & BIM
multi-cad users.....
i am going to work on another project but i really need help in deciding what cad program to use to be more time efficient..
is there a multi-user ( archicad +vectorworks or autocad), who can share with me how you use your program.
my dilemma is ; i find using autocad to generate 2d plans is faster than using archicad but i find easier to use archicad for 3d model. what i did in my last project is to draw 2d in one layer in autocad and export it to archicad where i draw over the lines with the tools to generate 3d. Somehow, i found it to be time-consuming......
any ideas>
version 7 on xphome
I have used ArchiCAD, AutoCAD, Microstation, speedikon, DataCAD, Vectorworks, etc... and I have found that none of the others is as quick to produce the building model and full documentation as ArchiCAD.
any ideas>
version 7 on xphome
It's no wonder you found it time consuming. It sounds like you're using ArchiCAD as if you were doing 3D in AutoCAD; i.e. drawing the plan first and then creating a model from it. You need to take the time to learn to start with the model in ArchiCAD. If you think of it as just drawing plans it can seem slower, but when you build the model properly you are actually creating all the plans, sections, elevations and 3D views simultaneously while also keeping them all coordinated.
I have also trained many AutoCAD users to use ArchiCAD, and once they've understood how the tools work (particularly the snaps, locks & constrains) most have agreed that ArchiCAD is actually faster for drafting than AutoCAD. The problem with changing CAD programs is always that they all have different patterns and work flows. This is particularly true when going from flatland to a building modeler.
thanks matthew...yes, for sure Archicad is faster and more time-efficient overall and I can testify to that experience in some work. I just got into the 'dilemma' situation when I have too many work at one time to handle esp.where clients used or have autocad drawings and want a 'fast' 3d model for conceptual study.
and your are right that i just have to get really familiar to the tools and the 'know-how' which will speed up the process.
Thanks!
