Project data & BIM
multistory hotlink
I have two separate files with different floor level heights. I want to link one file into the other as a module but the floor levels change when i put it into the document. the buidling on the right is the linked in module
Do a forum search - this question was just asked in the last couple of days, and is asked about once a month...
One of the forum moderators
i think because the story setting is based on the taller one , so the hotlinked module is placed in the same level as the taller building. you have the elevate the hotlinked module
