separate floor plan / elevation reference grids?
I use a floor plan grid a lot while drafting.
is it possible to set up a different elevation grid?
they are not the same dimensions.
i am about to set up a layer or something and manually draw a grid but did not know if there was a better way.
thanks.
David Maudlin
knosaj:
If you are referring to the Background Grid (Grids & Background), they have their own settings for each window, so you can set one grid for the plan and a different grid for the elevation.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
