updating template every version
Hi
I have a lot of window a door favorites saved on my templet I use to start new projects. The migration has certainly made things easier but I do end up using an older version of windows doors or having to go though manually and re save all my favorites.
Is there any downside to migrating my templet from the older version?
or any easy way to use the latest and transfer the settings without having to do it manually?
thanks
3 Replies 3
Erwin Edel
how about drawing one long wall, putting all your favourite windows / doors in the wall, copy + paste that wall in to the new template and use syringe to pick up the settings.
Library part migration should take care of recognising the new part.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
then inject the setting into the new version of similar window and save that as a new favorite?
that is actually what I had been doing before migration can along
Erwin Edel
Not sure which library you were using before, but generally, you can swap out the old library for the new one and it will migrate the objects. After that you could save them again as favourites.
www.leloup.nl
