Installation & update
Switched WIBU-code meter, getting error window for split sec
Ever since I switched from the old key (green plastic) to the new code meter key I often see my archicad icons (other open instances, not currently in front) bouncing in the doc. When I switch to those instances the error window immediately goes away (corrects itself) I'm pretty sure it is the hardware key not present error window...
Any ideas?
0 REPLIES 0
Learn and get certified!
