2009-04-28
04:14 PM
2023-05-11
10:25 AM
Noemi Balogh
2009-06-06 09:32 AM
2009-06-06 12:08 PM
2009-06-07 12:17 PM
PB wrote:
A query, if anyone can help please:
Can ED provide the temperature data for the building (and/or rooms) on an hourly basis throughout the year?
To explain: This would be particularly useful for a project in West Africa where I wish to provide a design that can provide a sufficiently comfortable environment without air-conditioning.......
2009-06-07 01:31 PM
2009-06-07 01:37 PM
2009-06-07 06:31 PM
rwallis wrote:No!
Mats could you expand on the relationship with VIP-Energy? Do I interpret correctly you need to buy ed and another program, or is this part of the ED package?
2009-06-09 09:56 PM
And you can also export out gbXML files for import into a range of ASHRAE 90.1-2004 compliant energy analysis tools–such as the new tools like Bentley Tas Simulator and Bentley Hevacomp which we touched on briefly here.This function on its on reduces the engineering inputs and should reduce their fee or allow them deeper investigation.
2009-06-10 09:45 AM
2009-06-10 05:44 PM
Mats wrote:Your terminology is a bit confused here:
I would like to comment about gbXML and GBS!
First data needed for energy analysis!
For Green Design this is in my opinion a absolute MUST.
When we have to calculate buildings with thicker insulation and higher energy saving standards or calculate natural ventilation or natural cooling then gbXML simply wont do. It have to many holes regarding things like infiltration and heat recovery. For Nordic condition gbXML was never an option.
Mats wrote:ED is an entirely different exercise. Real building simulation across an entire year of use is very computationally intensive - much like the calculations performed for radiosity rendering, only more involved because the model parameters change on an hourly basis as you move through the days and seasons. This is why the GBS analysis can take a long time (as any genuine simulation engine will). It may not be helpful to do this at a very early stage of design (presenting ideas to the client) when you may not have established the construction of the building fabric. All you want is 'rule of thumb' results - how is performance affected if I do this? Or that? Is my design improved or worsened? For example, our local planners were leaning on me to re-orientate a building to align with the road rather than the sun - a difference of 15 degrees. I would have very much liked to be able to quickly establish how damaging that might be to solar gains etc. I'm hoping that's what ED will deliver.
ED main goal is to mix simplicity and speed to let Architects make informed and accurate decisions for green design integrated in their design process.
2009-06-11 01:55 AM
KeesW wrote:I know that the answer to the above question was to read the whole thread, but I wonder if there is a more simple answer possible by puting the question this way: If one looks at Archiphysik demo he will see that at the end of the day the software can produce the energy performance document of the building and its energy consumption category. Can Ecodesigner do the same, and if not what we can do that will still be better than using Archiphysik?
Hello David
I am mistaken - I thought that it was a proper energy accreditation tool, in which case it would need to be accredited with our councils. If it isn't, why not? You mean that we have to keep manually re-entering data from our model into an Accurate, First Rate etc spreadsheet to calculate star ratings for energy approvals? Yet all the data for the spreadsheets is already contained in our Archicad model - if someone was clever enough to develop an interface.
Is EcoDesigner another almost perfect but handicapped add-on that Graphisoft is so good at producing (cf Lightworks)?
