2023-06-12 07:19 PM - last edited on 2023-06-12 11:24 PM by Karl Ottenstein
Hello, I have been trying to activate BimCloud Basic with my Graphisoft ID, but it does not accept the credentials. I have already checked that it is not an error when entering the password, but the problem persists, I have tried changing the password and everything is the same. Does anyone have an idea what is going on?
2023-06-12 10:33 PM
@Rosa Tavara Farro, there is an ongoing investigation regarding a BIMcloud Basic activation issue with Graphisoft ID accounts created on June 10 and later. We are working hard to fix this as soon as possible.
Let me know if you have registered before the mentioned date and cannot activate the product.
2023-06-12 11:45 PM - last edited on 2023-06-13 03:11 AM by Barry Kelly
I had an account registered with an educational archicad licencse since april, with that account i tried in frist place, after that i created two accounts yesterday, but it didnt work with any
2023-06-13 06:37 AM
I had the same issue, thought i was the only one
2023-06-13 09:34 AM
Activation should work with older accounts. Please contact your local Graphisoft representative for technical support.
2023-06-14 06:06 AM
Can you reply when the activation issue be fix?
2023-06-14 05:34 PM
@Rosa Tavara Farro, the issue has been fixed today. Give it a try and let us know about the result.
2023-08-03 05:26 AM
Hi i have the same problem as well, is there a way to fix for me as well??
2023-08-03 04:29 PM
@annakmp01, there is no known issue with the activation of BIMcloud Basic. If it does not work for you, please contact your local Graphisoft support representative.
