ArchiCAD Library 18 (Unavailable)
My office recently switched BIM Servers. My Library Manager now reads ArchiCAD Library 18 (Unavailable). It clearly shows that the IP address is incorrect. The IP address linked is to the old server. I have tried to Refresh and Reload the Library. I have tried to delete the Library and upload, which is not an option.
How can I correct this? I would greatly appreciate your time to help. Thank you. - Jakub
Erika Epstein
jakubgalczynski wrote:
I have tried to delete the Library and upload, which is not an option. - Jakub
Are you logged in with the correct permissions to change the library?
AT what point are you getting this as not an option?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erika, thank you for the response. One of my co-workers found a solution, which was to re-upload the ArchiCad 18 Library to the Server, on his computer, through Library Manager. I did the same process and it worked this time around. Seemed to be an issue only on my end. - Jakub
