Robert Nichols
BIM Server Mgr - what version is running?
Am I missing something or is there no obvious way to check what version of BIM Server Manager is running? There are very few Mac applications that don't have an "About" window...I don't know why BSM needs to be one of them.
Mac Studio, 32gb ram, ArchiCAD v26 (Apple Silicon) MacOS 13
4 Replies 4
This has been asked for from the beginning, but still is not present with 14.
You have to go to the actual app in the Applications folder and do a Get Info, but it only gives the base version - not the build number.
Rod Jurich
Or, you can look under the menu icon and select About.
See attached. HTH
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Or you can look under the menu icon and select About.
See attached. HTH
That's what Robert is saying ... Graphisoft did not put an "About" menu in their Mac implementation of BIM Server Manager. Your screenshot is of the BIM Server itself, Rod. 😉
Rod Jurich
Karl wrote:
/...Your screenshot is of the BIM Server itself, Rod. 😉
My mate "haste" again Karl
Rod Jurich
