Hi Ed
Long time no see, we talked about Bim server and the possibility of using the workstation as Bim server at the Nottingham Uni in September last year.
I tried that possibility, and it worked fine until my local disk space for OS went full with projects and their backups, in the time we brought a server and i moved the projects to the server with
2008 Windows server OS . Seems it was a "bad move". Still that move we had a lot of problem. The most persistent is the attached one with the
"unsuccessful teamwork operation" and "Connection to server failed" - 10 times at least/day/user
What do you mean, it is because of the OS, or other issues like settings and so on...
Thanks,
Best regards, Ede
