BIMcloud System Components
BIMcloud Manager
Services and Processes
WindowsmacOS
Main service
  • Service name: PortalServerService-v<Version>(Manager-<Date>)
  • Service display name: GRAPHISOFT BIMcloud Manager <Version> (Manager-<Date>)
  • Processes:
    • LicenseManager.exe
    • node.exe
    • TeamworkPortalServerManager.exe
Tray icon
  • Service name: TeamworkServiceProcessManagerAgent-v<Version>(Manager-<Date>)
  • Service display name: GRAPHISOFT Service Process Manager Agent <Version> (Manager-<Date>)
  • Processes:
    • BIMcloudMonitor.exe
    • TeamworkServiceProcessManagerAgent.exe
<Date>: The date the installation took place in YYYY-MM-DD format.
<Version>: Main version number of the BIMcloud Manager (e.g.: 24.0).
Main version number of the BIMcloud Manager is independent from the Archicad version BIMcloud Basic is locked to.
Main service
  • LaunchDaemon: com.graphisoft.PortalServerService-v<Version>(Manager-<Date>).plist
  • Processes:
    • LicenseManager
    • node
Tray icon
  • LaunchDaemon: com.graphisoft.TeamworkServiceProcessManagerAgent-v<Version>(Manager-<Date>).plist
  • Processes:
    • BIMcloudMonitor
<Version>: Main version number of the BIMcloud Manager (e.g.: 22.0).
Folder locations
WindowsmacOS
Folder Path
Installation * C:\Program Files\GRAPHISOFT\BIMcloud\Manager-<Date>
Configuration .\Config
Manager database ** .\Data
Logs .\Logs
*: The path can be modified during the installation phase.
**: The path can be modified either at the configuration phase after the installation or later by reconfiguring the BIMcloud Manager.
Folder Path
Installation * System drive/Applications/GRAPHISOFT/BIMcloud/Manager-<Date>/
Configuration ./Config/
Manager database ** ./Data/
Logs ./Logs/
BIMcloud Server
WindowsmacOS
Main service
  • Service name: TeamworkApplicationServerMonitor-v<Version>(Server-<Date>)
  • Service display name: GRAPHISOFT BIMcloud Server <Version> (Server-<Date>)
  • Processes:
    • mongod.exe
    • TeamworkApplicationServer.exe
    • TeamworkApplicationServerMonitor.exe
Tray icon
  • Service name: TeamworkServiceProcessManagerAgent-v<Version>(Server-<Date>)
  • Service display name: GRAPHISOFT Service Process Manager Agent <Version> (Server-<Date>)
  • Processes:
<Version>: Main version number of the BIMcloud Server (e.g.: 24.0).
Main version number of the BIMcloud Server is independent from the Archicad version BIMcloud Basic is locked to.
Main service
  • LaunchDaemon: com.graphisoft.TeamworkApplicationServerMonitor-v<Version>(Server-<Date>).plist
  • Processes:
    • mongod
Tray icon
  • LaunchDaemon: com.graphisoft.TeamworkServiceProcessManagerAgent-v<Version>(Server-<Date>).plist
  • Processes:
    • BIMcloudMonitor
Folder Locations
WindowsmacOS
Folder Path
Installation * C:\Program Files\GRAPHISOFT\BIMcloud\Server-<Date>
Projects database ** .\Projects
Libraries database ** .\Attachments
BlobCache database ** .\BlobCache
User sessions .\Sessions
Messaging database .\Mailboxes
Logs .\Logs
Files** .\Files
BIMcloud setup information .\Cluster
**: The path can be modified either at the configuration phase after the installation or later by reconfiguring the BIMcloud Server.
Folder Path
Installation * System drive/Applications/GRAPHISOFT/BIMcloud/Server-<Date>/
Projects database ** ./Projects/
Libraries database ** ./Attachments/
BlobCache database ** ./BlobCache/
User sessions ./Sessions/
Messaging database ./Mailboxes/
Logs ./Logs/
Files** ./Files/
BIMcloud setup information ./Cluster/
BIMcloud Delta Cache
Note that BIMcloud Delta Cache is not available in BIMcloud Basic.
WindowsmacOS
Main service
  • Service name: BlobCacheService-v<Version>(Delta-Cache-<Date>)
  • Service display name: GRAPHISOFT BIMcloud Delta Cache <Version> (Delta-Cache-<Date>)
  • Processes:
    • mongod.exe
    • TeamworkBlobCacheServer.exe
Tray icon
  • Service name: TeamworkServiceProcessManagerAgent-v<Version>(Delta-Cache-<Date>)
  • Service display name: GRAPHISOFT Service Process Manager Agent <Version> (Delta-Cache-<Date>)
  • Processes:
<Version>: Main version number of the BIMcloud Delta Cache (e.g.: 24.0).
Main service
  • LaunchDaemon: com.graphisoft.BlobCacheService-v<Version>(Delta-Cache-<Date>).plist
  • Processes:
    • mongod
Tray icon
  • LaunchDaemon: com.graphisoft.TeamworkServiceProcessManagerAgent-v<Version>(Delta-Cache-<Date>).plist
  • Processes:
    • BIMcloudMonitor
Folder Locations
WindowsmacOS
Folder Path
Installation * C:\Program Files\GRAPHISOFT\BIMcloud\Delta-Cache-<Date>
BlobCache database ** C:\ProgramData\Graphisoft\BlobCache\ServerCacheFolder
Logs C:\Program Files\GRAPHISOFT\BIMcloud\Delta-Cache-<Date>\Logs
C:\ProgramData\Graphisoft\BlobCache\Server\LogFolder
**: The path can be modified either at the configuration phase after the installation or later by reconfiguring the BIMcloud Delta Cache.
Folder Path
Installation * System drive/Applications/GRAPHISOFT/BIMcloud/Delta-Cache-<Date>/
BlobCache database ** System drive/Library/Preferences/Graphisoft/BlobCacheServer/CacheFolder/
Logs System drive/Applications/GRAPHISOFT/BIMcloud/Delta-Cache-<Date>/Logs/
System drive/Library/Preferences/Graphisoft/BlobCacheServer/LogFolder/
Browse more articles
Back to articles
