‎2018-02-22 05:45 PM
{"name":"_","process":"proxyServer","hostname":"BimServer.local","pid":8967,"namespace":"portalserver:undefined","level":60,"err":{"message":"listen EADDRINUSE :::21000","name":"Error","stack":"Error: listen EADDRINUSE :::21000\n at Object.exports._errnoException (util.js:1016:11)\n at exports._exceptionWithHostPort (util.js:1039:20)\n at Server.setupListenHandle [as _listen2] (net.js:1307:14)\n at listenInCluster (net.js:1355:12)\n at Server.listen (net.js:1455:7)\n at Server.tryCatcher (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/util.js:16:23)\n at ret (eval at makeNodePromisifiedEval (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/promisify.js:184:12), <anonymous>:14:23)\n at ProxyServer.<anonymous> (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/gs-proxy-server/ProxyServer.js:48:82)\n at ProxyServer.tryCatcher (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/util.js:16:23)\n at ProxyServer.listen (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/method.js:15:34)\n at /Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/gs-proxy-server/ProxyServerApplication.js:101:28\n at tryCatcher (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/util.js:16:23)\n at Promise._settlePromiseFromHandler (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/promise.js:512:31)\n at Promise._settlePromise (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/promise.js:569:18)\n at Promise._settlePromise0 (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/promise.js:614:10)\n at Promise._settlePromises (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/promise.js:693:18)\n at Async._drainQueue (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/async.js:133:16)\n at Async._drainQueues (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/async.js:143:10)\n at Immediate.Async.drainQueues [as _onImmediate] (/Applications/GRAPHISOFT/Serveur BIM 21/BIMcloud Manager/PortalServer/node_modules/bluebird/js/release/async.js:17:14)\n at runCallback (timers.js:800:20)\n at tryOnImmediate (timers.js:762:5)\n at processImmediate [as _immediateCallback] (timers.js:733:5)","code":"EADDRINUSE"},"msg":"Unhandled process exception in ProxyServer application.","time":"2018-02-22T07:57:43.275Z","v":0}
I think that server is crashing and trying to restart to a service which is already binding...‎2018-05-01 04:31 PM
May 1 08:42:43 camelot com.apple.xpc.launchd[1] (com.graphisoft.PortalServerService-v21.0): This service is defined to be constantly running and is inherently inefficient.Sorry I don't have a solution, just another user with the same problem.
‎2018-05-04 03:05 PM
Noémi Balogh
Senior Community Expert, Admin
‎2018-05-04 04:48 PM
