2024-10-06 10:16 PM - last edited on 2024-10-06 10:28 PM by Karl Ottenstein
Hi!
I am using BimCloudBasic through reverse proxy for Archicad 24, and my problem is, that I can not upload standard Archicad libraries in lcf format, because I get invalid file format notification for them.
Can someone help me with this issue?
Thank you in advance,
Zsuzsa
Operating system used: Windows 22
2024-10-07 09:14 AM
Does the lcf library work with a solo project?
Do other teamwork functions work with that BIMCloud basic server?
2024-10-07 11:41 AM
Dear Scott!
Yes, it works. They are actually the basic, built-in *.lcf files that I am trying to add.
Yes, the other teamwork functions also work.
2025-06-16 03:08 AM - edited 2025-06-16 04:06 AM
I was wondering why objects were not showing up even though the library manager was saying that all of the libraries were loaded, and it turns out that when I use the BIMCloud Manager to manually upload the libraries, .lcf is an invalid format...
AC22 on 2025.1
Have no issues with loading .libpacks for A28.
Ling.
ps. I found elsewhere that you cannot directly upload lcf files since BIMCloud converts them to a different format when you upload them... I did manage to load an AC21 3rd party library into the AC22 project and that works fine, it is just the AC22 default library that does not work...
Manage BIMCloud Libraries
Local Data Manager:
2025-06-16 04:37 AM - edited 2025-06-16 04:38 AM
Resolved: After re-sharing the project, I deleted all the missing libraries in the Library Manager and re-added them and now they load properly everywhere.
