‎2009-09-17 08:20 AM
‎2009-09-17 01:43 PM
‎2009-09-17 05:31 PM
‎2009-09-18 01:10 AM
‎2009-09-18 01:31 AM
‎2009-09-18 01:41 AM
rwallis wrote:The path to the library is basically <servername>/<library name> So, no matter how many projects you 'join' on that server, there will only be one copy of the library downloaded - when you join the first project.
You mentioned we only have to download the libraries the first time - is AC13 intelligent enough to remember a previous download (say a few days earlier) and update that one, or is a fresh download of the project library triggered upon each new opening of a file?
I suspect CADIMAGE and other add-on makers must be upset - there is one way to reduce this headache and that is to load a minimal library set...which has implications for them....(i.e. their non-use!)I don't think so. Those libraries are not so big, and again would be downloaded once, regardless of the number of projects ... assuming one worked with only a single BIM Server.
In our office we use a login script to sync all libraries on workstations with the server. Job specific libraries are the only ones that load across the network when we open a project. Even in the office we will now face a huge increase in network traffic, as whole libraries are downloaded every time we open a new file. Surely this has an effect on open file times?A synch approach like that is a pretty standard procedure (or should be). But, now, that only affects solo projects, not TW.
The server will not have duplicates. The workstation will. The workstation will have the standard libraries (that you are synching), and when it joins a project from the server, it will get another copy of all of those libraries. But, there will only be as many copies as there are servers - not as many copies as there are shared projects.Aside: on the BIM server we now must have heaps of storage for all the (duplicate!) libraries for each project? With the increased network traffic, I can see a dedicated server must be almost mandatory.
Regarding "issue 2", this too is very disappointing. For those who don't bring our home computers into the office, the loss of the ability to take files home on removable storage is a big step backward.I think nearly everyone will agree.
‎2009-09-18 01:57 AM
Wokka wrote:I think I answered in my response to rwallis. Right ... 'once off'. When you open again, there are no big downloads - only a 'receive changes' happens.
Does this mean every time I want to log on to a particular file, I have to download the Archicad library (R12 with Cadimage 200MB), plus the actual file (up to 150 MB)? Is it a 'once off' download, and even after logging off, closing down, opening up again, do I need to download it all (the libraries) again?
‎2009-09-18 02:16 AM
‎2009-09-18 02:30 AM
‎2009-09-18 03:19 AM
Wokka wrote:You're welcome ... rwallis, too.
Karl,
Thanks for the clarification!
Assuming 3 jobs for the one client. Each with server based Archicad library, company library and server based job specific libraries.
I have to firstly download the job files (no mem stick, dvd etc).
Does Archicad only download 1 copy of Archicad, 1 copy of company library, and 3 versions of job specific libraries? or
will it download all of them 3 times.....
