Lion - BIM server v14 hotfix 4202 - crashing
Have a new install of Lion and BIM server (running a few months). All seems to run properly for a while, then the Server Manager crashes on launch every time. The BIM Server Control Center will follow at some point. Users will just not be able to connect to the server anymore. A restart of the server does not help, only repairing with the installer fixes it for a while.
Server Manager log:
Dyld Error Message:
Library not loaded: @executable_path/_GSSupport/Teamwork.Server.ManagementTool.GUI.framework/Versions/A/Teamwork.Server.ManagementTool.GUI
Referenced from: /Applications/Graphisoft/*/BIM Server Manager.app/Contents/MacOS/BIM Server Manager
Reason: image not found
Server Control Center Log:
Dyld Error Message:
Library not loaded: @executable_path/_GSSupport/DG.framework/Versions/A/DG
Referenced from: /Applications/Graphisoft/*/BIM Server Control Center.app/Contents/MacOS/BIM Server Control Center
Reason: no suitable image found. Did find:
/Applications/Graphisoft/BIM Server/Server Modules/1400/TeamworkServer/BIM Server Control Center.app/Contents/MacOS/_GSSupport/DG.framework/Versions/A/DG: not a file
You should contact your local support about this.
