Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Teamwork & BIMcloud
Open and Repair - Failure to Repair warning
tsturm
Today I went to get into a Teamworked file. Received a warning that my file was not the most current and have to be opened from last opened.
I saved off the solo file.
I then went to run the repair on the solo file. It came back with a warning saying is was not able to repair the file. First time even trying to repair a file and I get this warning.
Today is not a good Monday.
AC24 running build 4018 using SAAS BIM Cloud. First time having this type of file issue using this service.
Anyone have similar experience?
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
Same problem here, if anybody has the solution kindly reply.
Noemi Balogh
I'm sorry to hear about your issue.
Based on your description, it sounds like something is corrupted within the project.
What I would do:
1. Save a .PLN copy of the project from one of the members who can still access it.
2. Open this .PLN with Open & Repair.
3. Re-share project on BIMcloud.
If you experience any further strange behaviour with your project, I suggest to contact your local support with an Archicad Teamwork SUpport Package and details about what you experience.
I really hope the repair and re-share will be enough though.
Let us know about the result.
Kind regards,
Noémi
Noémi Balogh
Community Expert, Admin
