I have run into this virtually non stop for the last 3 months...
I cannot REFRESH a library (that I've recently made changes to)... but I can RELOCATE and all is fine...
I'd like to also go over my workflow to get any feedback from you all...
With my own (bloated) libraries and AC Libs etc... it simply takes FOREVER to refresh them...
I make new objects DAILY or revise existing objects and if I could bill for the time WAITING to refresh, I'd be rich...
This also affects the act of simply updating an object... If I OPEN OBJECT from within the TeamWork File, Just switching from PARAMETER window to 3dSCRIPT takes WAY TOOO LOOOOONG... Then every time I type a line or switch a parameter, that nasty beach ball comes again...
In contrast, I have a file called OBJECT EDITOR that is NOT TEAMWORKED but linked to the same host libraries. So I edit in seconds, save... and REFRESH the library back over in my TW file... Used work FINE... But in the last 3 months, I have NEVER been able to REFRESH without seeing this error. I do a RELOCATE (which obviously takes much longer) and it rebuilds the TW Library and my updates are there.
Let me know how you guys are handling this kind of workflow...
I will test if CLOSING the EDITOR file first (before REFRESHING) has any affect...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
