Teamwork & BIMcloud
About Teamwork, BIMcloud, BIMcloud Basic, BIMcloud Software as a Service, network settings, etc.
Project Location on BIM Server
Hello,
We are having issues changing the location of the project folder on the BIM Server. On the BIM Server Control Center under preferences, you can change the Default Project Folder. However, when we open the BIM Server Manager and in the Project Settings dialog box try to change the Project Path on Server, it remains the same and is not editable.
Is it possible to change the default project location on the BIM Server?
1 REPLY 1
I have not tried this but I suppose this applies only for Projects shared after the change. See, it is a default setting, which usually applies to things created from here on.
So you could save the Project as Solo and reshare it. Then it should be placed into the new location.
