Project Preferences not staying in Teamwork.
After reserving project preferences and changing them successfully, each day when the project is reopened (after it was sent back to the server the day before when closing) the preferences go back to previous settings. All other changes made to the project are saving fine without issue.
4 Replies 4
Stress Co_
kfjerstad wrote:
...when the project is reopened (after it was sent back to the server the day before when closing) the preferences go back to previous settings.
Is it the "Working Units" that revert?
From the Help Menu:
"If you open a Teamwork project from the server, its Working Units will have
default values based on the template used to create the Teamwork project.
However, you are free to change these Working Units while you work on the
Teamwork project. Your Working Units preferences specific to each user, and are
not saved to the server when you Send or Receive changes
Marc Corney, Architect
Red Canoe Architecture, P. A.
I'm working in Archicad 18. Specifically, it's the dimension settings under Options > Project Preferences.
Stress Co_
To clarify... the setting displayed in this list, and then it was gone
when you reopened the project?
Yes, that is correct.
