Project starting to crash at "Post-Processing"
I recently migrated a project from Bim Server Module 14 to 15 and also updated the libraries to have the library 15. The project waorked for a couple days, even closed and reopenned it some times.
Now I can absolutely not get connected to it. The project invariably crashes at the same step in the process, right after checking libraries at the "4/6 post-processing step".
I am at my wits end trying to figure out what happenned. This is not the first time it happenned to this particular project and afer a very lenghty process of finding our old data I really dont want to go all over it again.
If anyone has an idea how to correct the problem or even the slightest insight why this is happenning, i'd be very grateful.
Using the latest hotfixes on AC 14 and 15 on an I7 Imac
Try deleting the local copy of the project. it can be found at
/Users/<username>/Library/Application Support/Graphisoft/TW Data/AC-<version> You will get a fresh copy of the project when you join.
Found the answer to my problem here:
http://www.archicadwiki.com/Bugs/Teamwork/CrashDuringJoinOrOpen
thank you wiki!
Edit: Also thank you for your reply, but I tried it and it didnt work, the project was inaccessible from any workstation until I changed the registry.
