2020-08-26 10:10 AM
2020-08-26 12:06 PM
Noémi Balogh
Senior Community Expert, Admin
2020-08-26 07:05 PM
2020-08-27 10:47 AM
subatomic wrote:
We'll be running one BIMcloud for use with 24. The other servers will stay in place until the projects are completed or we take them out of Teamwork. There will most likely be 3 or 4 projects between 1-2 GB with 2-5 users per project at a time.
subatomic wrote:
The other reason is that it is current running in a virtual machine on the file server.
2020-08-29 09:19 AM
I'd never run one of those Servers on a System, that is also a Fileserver, because I just can't afford to give away any "I/O - Speed" to another task like serving files.I don't recommend to do this either - BIMcloud is heavily relying on resources, and performance of Teamwork operations can be a nightmare when other applications hijack the resources from the program.
Noémi Balogh
2020-09-01 05:43 PM
2020-09-03 10:06 AM
Noémi Balogh
2021-01-22 08:33 PM
2021-09-08 07:58 AM
Hi Noémi,
Our current system, about a year old, is a HP ProLiant DL360 Gen10 SMB with a Xeon Silver 4210/2.2GHz and 64GB DDR4. It runs both a fileserver and our BIMcloud.
We have 10 BIMcloud licenses and about 16 projects, each with at least two files. File size ranges from 200mb to 500mb with some reaching over 1GB. On average there are about 8 to 10 files in use by 6 to 8 users.
Does this seem fine to you?!
Johan
2021-09-08 08:08 AM
SeRohde,
Do you mean that you would never create two VM's on one physical server for which one runs a fileserver and the other the BIMcloud?!
Johan
