ā2009-10-12 09:52 PM
ā2009-10-12 09:59 PM
ā2009-11-03 01:51 PM
kharrigan wrote:There is no fix, I had Graphisoft researching this bug and even sent them input/output logs. The only way around it is to not Force Sign Out but select Continue, it will look like it has quit then it will come back. Get another team mate (This error will only happen when someone else is signed in) to do a Send & Receive, then you should be able to do one. It is an enormous pain in the arse, and why I can't wait to start using AC13 on live projects.
Computer: MAC OS X 10.5.8, 4gb 1067 MHz DDR3
Archicad 12
When trying to send/receive I get the error, "Input file is incorrect or memory full", then after proceeding, "Error while loading plan file! Module:layout blocks." I get this every so often, have to force the user out. I tried saving as new plp. Not sure where to go from here.
ā2009-11-03 05:56 PM
ā2009-11-05 08:25 PM
