We value your input!
Teamwork & BIMcloud
TW access question?
Mats_Knutsson
I discovered that (AC21 have tried older) a user with server/project admin rights can join any project!? We will do some projects with strict rules regarding access (only the very few that will work on the actual project can have access). If I'm right that it's not possible...does it work with BIMcloud?
/Mats
AC 25 SWE Full
Noemi Balogh
Hi Mats,
Yes, on BIM Server if a user has at least Project Administrator Management permissions, he is able to see and join any of the projects. It is by design setting for Simplified Permission System what BIM Server uses.
However, on BIMcloud it is possible to use the so called Detailed Permission System, which allows you to configure more precisely what your users can access. For further details I would suggest to contact your local distributor.
Kind regards,
Noémi
Noémi Balogh
Community Expert, Admin
1 REPLY 1
Noemi Balogh
Hi Mats,
Kind regards,
Noémi
Noémi Balogh
