Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Teamwork & BIMcloud
About Teamwork, BIMcloud, BIMcloud Basic, BIMcloud Software as a Service, network settings, etc.
Teamleader appears as signed in, but really not signed in.
While saving a teamwork draft in AC v.11, the program crashed. The draft did not get saved and I was still signed in with exclusive access, but could not access the file because the draft had not been saved. Is there some way to resign in into the current signed-in position without having to enter as an administrator and force sign out so I can sign in again and not lose the work done?
1 REPLY 1
Edlyn,
The only other way is if your auto saved temp file was activated such that when you enter back into archicad it should offer you the option to open your auto saved temp file. If it does not do this at the time of initially opening Archicad then your only other option is to sign in as administrator & force log out.
Good Luck with it.
