Teamwork log in issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-01-22 04:19 PM
I was then told the file could not be found anymore, I had to find it manually. It would let me see the file, highlight it and choose it, but then it would act like I never did that, so after a few futile attempts, I gave up and closed the window. Also, all administrative information was lost at some point in this process.
Has anyone else encountered this problem? Any suggestions how to avoid it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-01-23 12:07 PM
However, this looks like a strange problem to me, actually multiple problems and my first thought was that this may not actually be a Teamwork issue, more like something else, because these phenomena can occur, but not together and at the same time. So I would try to check the computer and op system, if everything is fine with those.
But one advice, can you save a PLN file from the current state? Because then you could just reshare that PLN and get rid of this faulty file and work on that newly reshared copy.
By the way, you posted the exact same message twice in the same forum, so I deleted the other one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-01-23 03:59 PM
I can no longer get into the original plp file, but I was able to get in to a backup file and save a pln from that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-02-20 08:53 PM
AC issue or Mac issue? Problems seem to have begun after we switched users' home directory from being connected to our server via NFS to AFP.
Thanks in advance for any insight.
Bryon Yoder
Kitchen and Associates Architectural Services
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-02-21 07:32 AM
I am NOT a techie, so that's as far as I can go..
1. After SAVING PLC's, it is about every OTHER send receive that show the link to the plp broken and have to reconnect manually. About 90% of attempts to reconnect end in CRASH... I don't reconnect anymore.
2. So I'll work on plc and save it, quit archicad and re-open to S/R changes. This seems to work 90% of the time.
3. Every so often, I have to shut down mac to regain link.
4. Like others here, every so often I have to open either sign in as ADMINISTRATOR and force sign out crashing teammates or go to back up and save new PLN...
This can all be very frustrating, especially with 5 teammates and deadlines looming.
Keep me post on solutions.
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-02-23 08:46 PM
vfrontiers wrote:I'm convinced the majority of problems we have with TW has to do with the connection to the server. Not being a techie either, my diagnosis ends there. Lately, we've had PLPs disappear altogether!
Me too.... I am pretty sure it's a CONNECTION TO THE SERVER problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-03-31 11:51 PM
Anyone ever hear anything more on this??
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-04-28 10:22 PM
massachusetts, usa
Windows 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-05 06:30 PM
There seems to be some change in how Archicad is managing the links to the PLP file. I relocated all of the teamwork drafts and PLP file to my desktop and then disconnected from the server. When opening one of the PLC files I was prompted to reconnect to the server instead of the usual message that Teamwork cannot locate the PLP file. I was also asked to connect to the other teammates computer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-05-05 07:19 PM
massachusetts, usa
Windows 10
