Teamwork setting router netgear DG834
Hi everyone,
I'm trying to set ArchiCAD teamwork on a mac mini server using
Netgear DG834. I already made a previous attempt using the
Vodafone Station Snow Leopard with an iMac and a friend, and everything worked
well. I activated the service by setting the correct parameters and DynDNS
opened its doors 3 14001.14002 and 14004 required in the control center server
BIM.
Now with my router Netgear DG834 I set the DynDNS service, I created
the TCP / UDP ports for the 3, I created the firewall rules using
the three services previously created (but I also tried opening all ports
and using the DMZ server) but does not work. If you try the link from
ArchiCAD does not connect remotely, but then starting all diagnostics
controls appear with the green check, and then verified.
Has anyone had similar experiences with the router in question, is there any
Another parameter to verify that ran away from me?
Thanks to all
The parameters in the router to use ArchiCAD remote teamwork
are:
Router Model DG834
firmware version V5.01.16
DHCP ON
"Basic Settings"
NAT (Network Address Translation) enabled ---> if set to "off
firewall, internet does not go! normal?
"Services"
3 services created with the three ports 14001, 14002, 14004 also set on center
server control BIM
type: TCP / UDP
port start / end the same
"Firewall Rules"
added 3 services created before specifying the ip of the computer used
as a server
"WAN Settings"
set default DMZ server with the ip of the computer used as server
off DoS protection and research projects
"Dynamic DNS"
set inclusion as dyndns.org on, use wildcards checked
(Also tried without)
"UPnP"
activated
Thanx
Elvis P.
vfrontiers
I can setup BIM Server within my LAN... but outsiders cannot connect. I do not have an IT guy or a STATIC IP.... My Netgear router seems not to have all the options listed here....
If there are some step by step instructions for AC14 BimServer setup, please let me know where I can find them...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
