Unsent Changes in Teamwork
Hi All
We are having issues with linked views between two teamwork projects in 18. The linked view will not update because it says there are unsent changes on the host project when this isn't the case. I have tried the usual things of sending then receiving twice and then saving with out sending but have had no improvement.
The only way I can get it to clear is to close the host project down and delete the local data which is somewhat tedious and defeats the purpose of what we are doing. We have always been able to keep both projects live in 17.
Is anyone else using the linking in teamwork and if so are they having the same issue?
Okay, think I found how to get around it. For anyone else who comes across it.
Use separate
1. Send and Receive
2. Save
3. Send
Then it updates fine
