Teamwork & BIMcloud
Tips about Teamwork, plus BIMcloud functions and settings
bim server reserve and release problem
Hello,
I'm trying to reserve some views at the teamwork file and although I have reserved them I cannot interfere to my objects. The only way is to press the "reserve all" button.
Does anybody have a solution?
Thanks
3 REPLIES 3
I'm not clear what you mean by "interfere to my objects". Do you mean that you have the views reserved but cannot edit the elements visible in them? If so you probably don't have those elements reserved.
Thats what I mean.
I checked it and although I have the views reserved I cannot edit them.
The only way to work is to reserve all!!!
Link
As Matthew said you need to reserve the elements. You can do that by explicitly selecting them all and reserving them, or by right clicking on the view in the Navigator/Organizer.
Reserving just the view only allows you to edit the view and it's settings.
Link.
