2023-09-06 03:00 PM
We have been experiencing issue while updating hotlink module from Teamwork-Basic BIMcloud.
Hotlink module is not getting updated when we up[date from from Teamwork-Basic BIMcloud.
but when we keep the same Hotlink module on local server file path and then link and try to update it it works fine updates the file.
I just thought to check here if anyone else also experienced the same problem.
2023-09-06 03:16 PM
@amitchristian, link directly from BIMcloud (hotlink models, access SAF and BCF files and external drawings in Archicad directly from BIMcloud) is not a feature available for BIMcloud Basic, see Feature comparison: https://graphisoft.com/solutions/bimcloud#compare
