2020-08-05
12:22 PM
2023-05-11
11:51 AM
Noemi Balogh
2020-08-05 03:11 PM
2020-08-05 04:31 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-08-05 04:31 PM
2020-08-06 10:44 AM
mnguyen wrote:
Thank you for the question and I am very sorry about the issue!
I believe this is a known limitation, that was documented here: https://helpcenter.graphisoft.com/knowledgebase/75954/
As I saw that you had a big area of Grass, this could be the case with CineRender. Unfortunately, it is a limitation with the engine.
Thank you for your understanding! Let me know if it helps with the issue!
Best regards,
Minh
2020-08-07 02:50 AM
