3D Grass not working
So I have the grass button clicked in both the grass surface and my render options, but am still getting flat grass. Weirdly, it worked once this morning when I rendered, but now is rendering flat again, with what I think are the same settings.
Because it takes a while to process, I have even created a different project with just a 3x3 square of grass and it renders great and looks fluffy. I have checked both files and their settings for the grass surface and rendering process are the same.
Any ideas here or has anyone else encountered this? Thanks in advance.
2 Replies 2
glavounine
https://community.graphisoft.com/t5/Visualize-articles/Grass-blades-are-not-rendered-if-their-number...
there is apparently a limit in number of grass leaves per object. either cut the plane in multiple objects, or reduce density. just had same issue. confirmed.
