Visualization
3d model rising out of architectural floor plan.....
Ive always thought it would be a neat presentation technique to have model or partial model rising out of "the architectural floor plan"
Has anyone had any success in doing this.
Would they like to share the end result and how they did it?
Thanks again.
17 REPLIES 17
Dwight
That's a complex situation. I have only done parts of it......
Alternatives:
You do have the Construction Simulation Goodie. I have never used this.
Then there was the Aftermarket Object that took a GDL object and scaled it vertically in an Archicad animation. It worked well and was believable if buildings were rubber.
In Artlantis, it is simple enough to animate the scale of any object - you could make a thing flat, then move to its proper height. The components cold be timed with key frames.
Of course, this can be done with a combination of tricks, including an animation of the vertical scale, say, of building columns, then floor plates, then use a slide show to cross fade into successive images having additional building components to complete the building. After all, we see buildings rise up daily, but only as far as the frame goes - then panels are added whole.
As far as the floor plan goes, you would make a surface skinning material of the floor plan drawing to complete the effect.
Sorry for the hypothetical nature of the reply....
Dwight Atkinson
Link
Depending on your desired results it should be pretty easy. Just save your floor plan as a DWG. Then use the Open Object command to open that DWG and then save it as a (GSM) library part. Place that libary part so it aligns with your model. It wll be visible in 3D and you could use SEOs to show your model rising out from it.
Link.
Great image, Link. Sad that Microsoft Windows' cheesy 'tada' sound comes to mind upon seeing the graphic. šŸ˜‰
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Dwight
I assume Lennox needs an animation of some kind.
Since we went through this last year without success, did anyone finally manage to animate a cutting plane or SEO?
Dwight Atkinson
You could create a simple animation, using Links technique and 3D cutaways to create a series of images and then stitch them together using Adobe ImageReady or something similar.
The bug from last year involving the image not being rebuilt when the cut plane was moved in the GDL script was confirmed by GS. I kind of remember seeing that it might be fixed now... but have not tried it again in the latest build of 12 to see...
vfrontiers
Here's an untested hypothetical... proabably on the same lines as the cutplane, but why not....
1. Create a 3d object (slabbish) that is set as the boolean OPERATOR on your entire building (most likely saved as an object itself)
2. In this object you can have it's height variable by frame number
3. Insert Link's DWG plan (not cut by operator)
4. Set layer of cutter to WIREFRAME (or simply apply INVISIBLE material) so it never shows in rendering
a. on the other hand, make sure it's on a wireframe layer and give it a material that you can use as the CUTPLANE Material for the house i.e. when the building grows up, the edge of cuttedness is black or Richard Meier Orange...
5. Render....
If you use Subtract w/ UPWARDS extrusion, placing the cutter below the lowest part will show NO BUILDING until such time as the bottom of the cutter passes the bottom of the building.
Sound's like it should work!
Thanks for letting me play
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
vfrontiers
A quick test shows pretty much what you're after....
One caveat....
1. Had to use CURRENT FRAME - START FRAME or the multiplier went too quick (didn't start on 1!)
Duane
Visual Frontiers
Dwight
Excellent news!!!
Now, what was that GDL object that scaled the model vertically in an animation?
Dwight Atkinson
