‎2016-08-14
07:29 AM
‎2023-05-11
11:58 AM
Noemi Balogh
‎2016-08-22 05:38 AM
John wrote:I wonder if you are navigating using the Tabs? If so, are you are aware that a single click on the tab is sort of like switching using the Project Map, and that you need to
i never had this kind of problems before. I know that AC 20 kind of saves each open window tab settings somehow,
but camera used to maintain their set views regardless of what their view map settings were..
am i missing something or is there any extra steps or anything that must be done now, in order for me to be able to produce that kind of set-up?
‎2016-08-22 07:58 PM
Richard wrote:Nope, i was navigating using the view map on the project navigator by double clicking on them.
I wonder if you are navigating using the Tabs? If so, are you are aware that a single click on the tab is sort of like switching using the Project Map, and that you need todouble-clickon the Tab to get the View to update completely?
‎2016-08-22 08:06 PM
‎2016-08-22 08:17 PM
John wrote:Yes, you can set it up by going to your forum Profile>Settings, and checking that you will get notifications, or checking the box on the options below the text box when you reply.
By the way, can i get notification when someone replied to my post?
