Visualization
Render your model with built-in or 3rd-party solutions
AC logo bug in Int. Engine
I was preparing a lecture on rendering and found this bug in Internal Engine for AC 11 Educational.
AC puts its logo and some text upon the finished rendering. But their magins are too large and block the picture!
The same happens with Sketch render.
There in no such a problem with LW.
2 REPLIES 2
Are you sure you haven't set a 'partial rendering' range in the internal rendering setup? It will apply to both the int and sketch engines but not the lightworks one.
I wish it was that simple!
I opened another perspective view and it rendered fine. Then I renderes the previous one and had the same problem!? So, 2 views render fine and two don't!
