AC12 elevations
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-08-21
12:54 AM
‎2023-05-26
03:01 PM
Rubia Torres
‎2008-08-21
12:54 AM
When a cylindrical shaped wall is viewed in 3D either as a Internal or OpenGL generated image the joint line of the two halves are visible. I did bring this issue up once before but I didn't expect this to persist in AC12. I realize I rotate the cylinder but then joint will show in a different view!
When a elevation generated by a Elevation Marker is converted into a PDF file the vertical wall segments lines are clearly visible especially if the cylinder is rendered in a dark color (see attached image). This is also true in Internal 3D image.
In AC 12 only
To see the result of the setting change made in the Elevation Selection Settings > Model Display > Final Uncut Surface I have to open a different elevation model in View Map, and back to the original again. Example if the original elevation did not have the material color displayed, after I have selected ‘Own Material Colors’ to show them, I have to select and open a different elevation view then reopen the first elevation to see the change. Very odd!
I did not have to go through these steps with the AC 11 generated elevation views. The change in material color display or the reverse was immediate.
Thanks.
Bala
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 11:00 AM
‎2008-12-04
11:00 AM
image file is easier for preview than pdf do.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 01:27 PM
‎2008-12-04
01:27 PM
ArchiCAD unfortunately cannot make a full circle Wall.
It has to create it using two half circle Walls.
If you go to the Floor Plan or 3D you will see that the two halves can be selected separately: it is actually two Walls.
It is a technological shortcoming, I guess.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 07:39 PM
‎2008-12-04
07:39 PM
I hope future versions of AC will accomplish a full circle without any breaks. As for the smaller segmented vertical lines as shown on the pdf file (see earlier part of this discussion string) is this also a shortfall of AC 12?
Thanks.
Thanks.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 10:19 PM
‎2008-12-04
10:19 PM
Bala wrote:It's still the same in AC12 I'm afraid. One possible work around is that you
Another method may be to draw the circular shape on plan with fills and then paste into the complex profile manager. If you set this for use with a column, which simply extrudes a shape upwards, it should appear seamless on plan.
The downside is the difficulty in placing doors and windows into it. The workaround (to the workaround!) is to place some slabs to SEO the openings from it, which can then be hidden. Place doors and windows into discrete pieces of curved wall put into the openings.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 11:36 PM
‎2008-12-04
11:36 PM
Thanks Peter. Hopefully we don't have to employ all these work around solutions sometimes in the near future.
Happy Holidays.
Happy Holidays.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 11:43 PM
‎2008-12-04
11:43 PM
I wouldnt count on it. In AC, I think a wall has to have six sides, by its very nature.
You can always rotate it, to hide the seam as best you can.
Link.
Link.
