Tim Ball
AI Rendering Experiments
I see Bim6x have been experimenting with Rppm GPT so I bought some credits and started experimenting myself.
So far not great because there seems little real control. Anyone else looking at this?
Attached images are a rough render from AC and 3 AI options
AC source AI Experiment.jpgMinimalist-Living Room.pngModern-Living Room.pngNeoclassic-Living Room.png
Tim Ball
AC26, iMac
User since V5
5 Replies 5
Could you provide some more details?  I assume you provided the source room image to roomGPT (I assume that's what you mean by Rppm GPT?) ... so then what was your text input to produce the 3 AI modified images?
jl_lt
Ace
Look great! I understand what you mean about control, but the way i see these current AI tools is for rapid explorations of ideas so we can make better and informed decisions.  Question, if you go for example with the option "modern-living room", can one add even more detail to that image?
Tim Ball
Apart from picking the basic option images, I can't see any other way of inputting text.
Although the speed and say interface is attractive, Its not yet a workflow that gives me usable images.
Interested to hear of others' experiences perhaps with other AI engines.
Tim Ball
AC26, iMac
User since V5
Qubits Building Sets
40 seconds later, your Modern is enhanced
It helps if I upload the re-processed image. Hope you don't mind. Your test image from ArchiCAD was dropped into KREA AI.
