Djordje
ATL export error
Have you ever had "Cannot save file" when saving ATL from the 3D window?
If you had a zero height wall in your project, you did.
I have learned the hard way ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
4 Replies 4
Djordje
Some more info on the topic ... although nobody is interested 😉
On the Mac, it seems that having no texture on the outline, but having the texture on the sides of the wall, will cause the same.
Bottom line: set your wall heights to a very small value if you need them to show the lines on the floor ...
Djordje
HP Omen
Useful info for sure. Though not exactly an invitation to heated debate 😉
Thanks.
Rafal SLEK
What? 🙂 I've read it three times and try to learn by heart 🙂
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD Collaborate
Djordje
Djordje
HP Omen
