Adding New Surfaces to BIM Server / ArchiCad 18 Library
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-11-05
01:49 AM
2023-05-11
12:50 PM
Noemi Balogh
2014-11-05
01:49 AM
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-05 04:46 AM
2014-11-05
04:46 AM
Surfaces are attributes that are stored in the actual Archicad file.
So you either need to create new ones in your file (and/or template) or use the Attribute Manager to import them from other files.
The texture files (i.e. jpg) are stored in the library and they can be used in your surfaces but you have to edit the surfaces in the Archicad file itself.
You can add them into your existing office library or even create a new library for your textures.
Don't add them to the default Graphisoft library as they will be replace if you ever update it.
Then just make sure the office library is re-loaded or the new library is loaded in you file.
I'm not sure exactly how that works with teamwork - but I assume you just need to update or add a library to your BIM server and then have all users re-load them.
